Pyramid Table
    I am trying to create a pyramid table one next to the other. One box on top, then two, 3 and then 4 at the bottom. For some reason when I do so the alignments are all wrong and I have check all grid and container settings and centered everything but the table is always off center.
    I have included the actual page with the table in the bottom in the private info.
    Thank you.
    I can’t quite picture what you meant by a pyramid table.
    Can you provide an actual example of what you are trying to achieve?
