Query Block
  • Hello. If I use one of three container query blocks, and use it in a elemnt that is at the bottom of every post, is there a way to block the post from appearing in the query block? For example; I have a three query block with posts A, B and C. On post A, how do I prevent the query block from showing post A and have it show post B, C, D?
    Yes, you can add the exclude posts parameter to the query block, and choose current post.
    Note that it requires GB Pro.
  • Thank you.
  • You are welcome   🙂
