Query Carousel
  • Hello, I added my own query to the Carousel query. The problem is that Carousel Control and Carousel Pagination stopped working.
    How can I fix this?
    You can not use another query in the carousel query, it has to be the default query.
  • Can I edit Loop Item so that it looks exactly the way I want it to? Check the URL again in the Private Information section.
    I want to achieve the same look, but with Carousel Pagination working.
    Thank you 🙂
  • Hi there.
    Yes, this is possible, you can style your query loop like you always with GenerateBlocks, set Slides Per View to 3 and Slides Per Group to 3 also.
    Carousel settings
