Is it possible to use the query loop block to show upsell or crosssell products?
That should be possible if you know which parameters to include to set an upsell product for a specific item. Assuming you’re using WooCommerce, doesn’t it have its own method for displaying upsell and cross-sell products?
Yes, but i want to place them in between content and want to make a slider out of it. The only thing i need to know is how i can use the query loop for it.
Here is the site –> http://pottauchocolat.hpgu4slzdh-dv13xyw576gq.p.temp-site.link/erdnuss-28-weisse-schokolade-kopie-2/
This is the layout i want to achieve –> https://ibb.co/sKF5WJd
Do you mean how to use query loop to pull products? If so, you just need to select product as the post type, and set your specific parameter.
I need the specific parameter for the upselling/crossselling products.
That’s for you to determine, as you’ll need to define the criteria for selecting upsell products for a particular item. To simplify, you could set the upsell products to be from the same category as the currently viewed product.
That is not quite the thing i wanted to achieve but good enough. Thank you!
You’re welcome!
