Query Loop Custom order having issues
  • Hi everyone,
    I have done this before, but for some reason this time it is not working.
    I have set this up only on SURF on the provided page – each section is in an accordion.
    The Grid has the Class entered (order_by_object_name).
    The PHP is:
    add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) {
        // apply filter if loop has class: order_by_object_name
        if (! empty( $attributes['className'] ) && strpos( $attributes['className'], 'order_by_object_name' ) !== false) {
            return array_merge( $query_args, array(
                'meta_key' => 'object_name',
                'orderby' => 'menu_item_order',
                'order' => 'ASC',
        return $query_args;
    }, 10, 2 );
    Originally the custom field menu_item_order was a number (via ACF), but I changed it to a text field, but no change.
    The PHP is entered in the child themes function.php
    ACF field (name a text field) is menu_item_order
    All that happens is that no menu items appear!
    I have tried a couple of different versions of this filter, but they all have the same result – probably missing something simple!
    TIA, Dave
  • Hi Dave,
    orderby be set to meta_value so your field’s value is taken into account. Reference: https://docs.generateblocks.com/article/order-query-loop-by-custom-field/#example-b-text-values
    Have you tried that? Or, are you trying to achieve something else?
  • Thanks Fernando,
    I just had the meaning of the fields the wrong way around…
    All clear now and working 🙂
    Dave
  • I see. You’re welcome!
