honzapecenka
I have created a content template for specific posts. Each post has several tags. Through secure custom fields I have created a field (slug selected_tag) in which I select one specific tag.
I need to display a query loop in that content template with the posts that have a tag defined via the selected_tag field.
Is there any way to do this?
What is the custom field type? Is it a post-meta or a taxonomy? Can I have more info about it?
honzapecenka
Then you should be able to add taxonomy parameter > selected_tag to the query block.
honzapecenka
Not sure what you mean, here’s a screenshot for your reference:
https://app.screencast.com/1D7jRoDZjCAHU -
honzapecenka
I don’t want to list by category, but mainly by specific tag, which I define via SCF (taxonomy field – tags).
https://prnt.sc/5KIa0GwxvYO8
In Query Loop I see only this:
https://prnt.sc/T5UM_7sIytzD -
Why not just use the default WP tag?
I don’t see an advantage of your current setup, or maybe I misunderstood your purpose.
honzapecenka
Yes, this is a WP post tag. I have several posts, each with several tags. The posts are made using Content Template, so I need the query loop in each post to be generated automatically based on the tag defined via the custom SCF selected_tag field.
It’s like defining a primary tag for the current post?
I don’t think there’s a way out of the box, you will need to write custom PHP to alter the query loop output.
honzapecenka
This is exactly what I mean.
If you are V2 GB block, then try this PHP code, and add
selected-tags-posts
class to the query block.add_filter( 'generateblocks_query_wp_query_args', function( $args, $attributes ) { if ( ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'selected-tags-posts' ) !== false ) { // Get the current post ID $post_id = get_the_ID(); // Retrieve the selected tag(s) from the ACF field $selected_tag = get_field( 'selected_tag', $post_id ); if ( $selected_tag && is_array( $selected_tag ) ) { // Extract tag IDs $tag_ids = wp_list_pluck( $selected_tag, 'term_id' ); // Modify the query arguments to include these tags $args = array_merge( $args, [ 'tax_query' => [ [ 'taxonomy' => 'post_tag', 'field' => 'term_id', 'terms' => $tag_ids, ], ], ] ); } } return $args; }, 10, 2 );
honzapecenka
I have the latest beta version of GB Block.
I put the CSS class here:
https://prnt.sc/E3ybAmFrp_Du
Is it ok? Because this doesn’t do anything. In the query loop parameters I have the option taxonomy – tags – current post terms. -
You are using V1 block, are you going to update to v2? it’s now at beta 6 stage.
If not, then we need to switch to the legacy filter:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if ( ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'selected-tags-posts' ) !== false ) { // Get the current post ID $post_id = get_the_ID(); // Retrieve the selected tag(s) from the ACF field $selected_tag = get_field( 'selected_tag', $post_id ); if ( $selected_tag && is_array( $selected_tag ) ) { // Extract tag IDs $tag_ids = wp_list_pluck( $selected_tag, 'term_id' ); // Modify the query arguments to include these tags $query_args = array_merge( $query_args, [ 'tax_query' => [ [ 'taxonomy' => 'post_tag', 'field' => 'term_id', 'terms' => $tag_ids, ], ], ] ); } } return $query_args; }, 10, 2 );
honzapecenka
I have the latest beta 6 version of V2 GB Block.
Can you confirm if both GenerateBlocks and GenerateBlocks Pro versions are on V2?
