query loop equal heights when one item is set to span multiple columns
  • I followed David’s recommendations at https://generate.support/topic/querryloop-two-columns-except-the-first-one-with-gb/ on setting up a multi-column item in a query loop (thanks!) but can’t seem to get the last column in that grid to render at full height regardless what I try. I assumed the solution would be setting the container to flex, column, stretch then set the images to min 100% height but that did not work.
    You can see what I mean at https://stg-morikami-staging.kinsta.cloud/private-event where the “Photography and Videography” item image is not full height.
    Suggestions?
  • Hi Drew,
    Try this:
    First, select the .gb-element-7371120c container inside the Loop Item block, then apply these settings:
    Display - Flex
    Flex Direction - Column
    Height - 100%;
    Next, select the container that wraps the image block. Under Layout > Flex Layout, apply:
    Flex Grow: 1
    Flex Shrink: 1
    Flex Basis: 0%
    Lastly, select the Image block and apply:
    Width: 100%
    Height: 100%
    Object Fit: Cover
  • With the exception of placing the image in a container and applying those settings, that’s what I had in place. So adding the container and applying those settings did the trick, many thanks!
  • Glad to hear that!
