Query Loop for Comments?
  • I’m interested in creating new views of things like Latest Comments, Hot Topics, Most popular commenters, etc. on our front page.
    Is it possible to use a QL block to query comment data in this way? Any suggestions would be appreciated, thanks!
  • Hi Marty,
    What’s easily possible through custom code is to order the Query Loop by the most comments.
    Ordering posts by the most recent comments would be more complicated and out of our scope.
    Getting the users with the most comments is not a feature available in the GB Query Loop. You’ll need a custom code for this. I found this article which may help: https://www.isitwp.com/display-user-with-the-most-comments/
  • Appreciate the insight, thanks Fernando!
    Could you share an example of code to do this, and does is using the QL block?
  • Add cu-query-loop-com to the class list of the Grid Block under the Query loop.
    Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Then, add this Snippet:
    add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) {
        if (
            ! empty( $attributes['className'] ) &&
            strpos( $attributes['className'], 'cu-query-loop-com' ) !== false
            return array_merge( $query_args, array(
                'orderby' => 'comment_count',
                'order' => 'DESC',
        return $query_args;
    }, 10, 2 );
