Query Loop inside GeneratePress Carousel block?
  • Is it possible to combine the GenerateBlocks Query Loop with the new GeneratePress Carousel block?
    I want to load ±10 posts from the category “projects” via a Query Loop and display them inside the carousel instead of a static layout.
    Does the Carousel block support dynamic content from a Query Loop, or is there a recommended workaround within GeneratePress?
    Desired situation:
    carousel
    You can insert a carousel block and select Query as a the layout.
    Carousel query layout
    Then, adjust your query accordingly.
  • Missed that completely. Thanks!
  • No problem!
