Query Loop : Not apply limit
    I need your help with a behavior that I can’t explain.
    I’m trying to redo my home page and so for that I use the query loop to retrieve only the last article which is of type “post”.
    For this I configured my query with 1 publication per page and an offset of 0, which corresponds to the limit 0.1
    To put it simply, it does not only work in the case where I select the post type “post”, if I select another CPT, the query parameters are applied.
    Would you have an idea?
    When you say “the last post,” do you mean displaying the oldest post?
