Query loop with empty (non-content) columns
  • Ehy there dear team,
    Do you think it’s possible to create a structure like this? (I’ve attached an example in the private info.)
    Basically, it’s a query loop with a grid layout, and every few columns there’s one column containing an image (so it doesn’t display any post content).
    I’ve tried experimenting a bit, but I can’t get it to work. Is this possible with the current query loop, or does it require custom code?
    Thankss
    So you want to insert content between the posts at random places?
  • Ehy Ying,
    exactly!
  • 1. Add this PHP code:
    add_filter( 'render_block', 'yh_render_loop_items', 10, 3 );
    function yh_render_loop_items( $block_content, $block, $instance ) {
        if (
            'generateblocks/loop-item' === $block['blockName'] &&
            ! is_admin() &&
            ! empty( $block['attrs']['className'] ) &&
            strpos( $block['attrs']['className'], 'my-loop-item' ) !== false
            $loop_index = $instance->context['generateblocks/loopIndex'] ?? 0;
            // Define your custom insertion points:
            $insertion_points = [
                2 => 'after_first_loop_item',
                4 => 'after_third_loop_item',
                11 => 'after_tenth_loop_item',
            // Check if current loop index matches one of them
            if ( array_key_exists( $loop_index, $insertion_points ) ) {
                ob_start();
                do_action( $insertion_points[ $loop_index ], $loop_index );
                $additional_content = ob_get_clean();
                // You can choose to prepend or append
                $block_content = $additional_content . $block_content;
        return $block_content;
    2. Modify this section to suit your needs:
    3. Add my-loop-item class to the loop item block.
    4. You can use block element – hook to insert content, and set the hook name to after_first_loop_item/after_third_loop_item/after_tenth_loop_item to different places.
  • Hey Ying,
    I’m trying to test it. When I add the hook name, it doesn’t find those values you gave me as examples. Here’s a screenshot: https://imgur.com/uLqlklS
    So I can’t add them as hook names.
  • These are custom hooks you just created, so select custom hook, then enter the hook name.
  • Oh, I missed that I could add a custom hook, thanks!
    Anyway, unfortunately it doesn’t work. I checked the code with ChatGPT and it suggested adding this line at the beginning of the PHP code (before the function yh_render… part):
    This way, I see that it works. Does that make sense to you? I’m asking because I’m not very familiar with PHP and I’d rather have your confirmation than GPT’s :’D
    Yes, that’s correct — the function needs to be hooked to the render_block filter. It looks like Ying might have missed adding that part in her code. 🙂
  • Hi Alvind,
    great! Thanks guys,
    have a good day
  • No problem, you too! 🙂
