Query loop with flip box post template
    Is it possible to have a query loop block with flip box effect in the post template block?
    I looked for some topics here, like this one, but couldn’t get it to work. Probably my CSS skills are not up for it, but I was also wondering if the query loop interferes with it, making it hard if not impossible to use the effect.
    Thanks.
    Using that flip box effect from the example in the query loop should be no problem. Did you follow all the instructions?
    I noticed that there is a mistake in the structure layout, though. The last container class should be flip-card-back.
  • Hi Alvind,
    Yes, I did spot the typo. But for some reason the result is not good. I wonder what’s the post template block config that is compatible with that code. Is it the default one, or do I have to change, for example, the Layout configs, like Display and Position? Also on the child containers, along with adding those CSS classes.
    Thanks.
  • Can I see your site where this effect is being implanted?
