dieter
I want a query loop in the sidebar that only shows updated posts.
I have set this: Sort by: last modified date
However, it is now the case that new posts that are published are also displayed. They have not been updated but are still displayed.
How can I ensure that only updated posts are displayed?
Thank you very much for your help. -
WordPress saves the a modified date for all new posts, it just happens to be the same as published date.
So to exclude all new posts, you need to tell the WP Query to exclude any posts where the modified and published dates match.To do that in a GB Query Loop block:
1. Add this PHP Snippet to the site:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if ( ! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'mod-post-only' ) !== false ) { $query_args = array_merge( $query_args, array( 'date_query' => array( array( 'column' => 'post_modified', 'after' => 'post_date', ), ), )); } return $query_args; }, 10, 2 );2. select the Grid Block inside the Query Loop
2.1 in the block settings Advanced > Additional CSS Class(es) add:mod-post-only -
dieter
Hi David,
thanks for your explanation – that makes sense.
I copied the code into my function.php in the child theme and added the CSS class to the Grid Block.
But it does not work. New posts are still listed (I have double checked the implementation).Any new ideas?
Yeah, to be honest, it was some potluck shooting on my part here…. and looking at it now, was a bit dumb as the
afterarg requires an actual date.So… not 100% sure on this but you could try:
1. Remove thea above snippet
2. add this snippet to create a custom query arg of:
exclude_unmodifiedadd_filter( 'posts_where', 'exclude_unmodified_posts_where', 10, 2 ); function exclude_unmodified_posts_where( $where, $query ) { global $wpdb; if ( $query->get( 'exclude_unmodified' ) ) { $where .= " AND {$wpdb->posts}.post_modified != {$wpdb->posts}.post_date"; } return $where; }3. Add this snippet to write in our new arg.
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if ( ! is_admin() && ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'mod-post-only' ) !== false ) { $query_args = array_merge( $query_args, array( 'exclude_unmodified' => true, )); } return $query_args; }, 10, 2 );4. as above add the
mod-post-onlyclass to the query loops grid block. -
dieter
Thanks David,
your new snippets work – really good work, thank you very much.
Best support!Have a nice day and greetings from germany 🙂
Awesome – glad to hear that worked!
