nathorius
I want to create something as nytimes has (they are using WordPress it seems) with how they do sections on the front page, see example:
[img]https://i.postimg.cc/RVFR7tHS/temp-Image-VPUMi7.avif[/img]
I can make something like it, but then with a Grid and point the img manually. But is it possible to make a grid and query loop and show 2 or 3 posts in the left part and the image of the first post (with undertitle image text) in the right part?
I tried using Featured image on Curren Post, but I think that does not work since it is not in the “Post Template container”. I tried with css class too on the Grid (cu-featured-img) but I get lost there too.
And: how do I get a separator line between the posts? Meaning that I want a separator line between post 1 and 2, but no separator line under post 2. That won’t work with a border since that repeats.
Hope my question is clear, best Geert
Do you have GP Premium? We have a template that looks structurally the same as the example you showed above: https://gpsites.co/voice/
nathorius
Yes I have. Thank you for the suggestion, but I think it looks different as this shows a big photo above the post (the central one) if I am not wrong. What I am asking is showing 1 photo (first) in a query with multiple posts.
post 1 title. | Featured image of post 1
excerpt. |
— (separator) |
post 2 title. |
excerpt. |
it would require 2 query loops to do that.
You would first use a Grid Block to create the 2 columns. Making the first column 70% wide and the second column 30% for example.
Then add a separate query loop within each,. -
nathorius
That is a nice approach. Thanks!
Any light on the separator too? Only in between posts?
Can I see what you’ve done? And let me know where you want the separator.
nathorius
I missed your reply. This is what I made of it:
https://broad-horizon.eu/No separator added yet. Was thinking of using a block border at first.
I checked your site, but I’m not quite sure which part you’re referring to for adding the separator. Could you clarify where exactly you’d like it placed?
