Query Loops current post id
  • Hey there,
    I’m using GB Query Loop. I want to create a links to a specific posts within the query loop, and for that, I need to add id=”current-post-id” to each gb-grid-column in the loop.
    It should look something like this: <div class=”gb-grid-column gb-grid-column-e05b6adc gb-query-loop-item post-6620″ id=”post-6620″>
    Could you provide the code for a filter or hook?
    Thanks.
    try this PHP Snippet to add the Post ID to the Query Loop Item:
    // Add post-id-{get_the_id} as ID Attribute on all query loop item
    add_filter( 'generateblocks_attr_grid-item', function( $attributes, $settings ){
    	if ( $settings['isQueryLoopItem'] && !is_admin()  ) {
        	$attributes['ID'] = 'post-'.get_the_id();
    	return $attributes;
    }, 10, 2 );
  • You’re the best, thanks!
  • You’re welcome
