Query or Query Loop unresponsive
    The query blocks became unresponsive, and other bloks too (wp gallery, wide containers) I can’t find a behaviour pattern.
    First I thought that I was doing something wrong with GB V2.
    So I downgrade to V1 with a code snippet. However it happens with V1 too.
    I am working in a stage site and I disable every caching plugin (not the Cloudways server caching) and other plugins too.
    It happens with the last articles I had published and there are in different subsites.
    Also the logo image in the author box doesn’t resize (Element)
    You are in the editor, can I take over and have a look at the blocks?
  • Hi Ying
    I loged out
  • Hi Irene,
    I checked both pages. The problem comes from a Width setting on the outer Element blocks, not from the Query Loop itself.
    On both pages, the outer Element blocks have Width set to a fixed value (1000px, and one at 900px). That keeps them at that width on mobile, so the Query Loop, gallery and everything else inside them overflows the screen.
    – provincia-de-tucuman: .gb-element-43cbe1fe, .gb-element-51eb0cec, .gb-element-e79bc177
    – barrio-de-la-boca: .gb-element-8be26330, .gb-element-c59022f4, .gb-element-5d5d0115
    To fix it, select each of those blocks and:
    1. Go to Styles > Sizing and clear the Width value.
    2. In Max Width, remove the Container width token and enter 1000px (or 900px for the last one).
    Max width keeps the content at 1000px on larger screens but still lets it shrink on smaller ones.
    For the author box logo, it scales to the full column width on mobile. If you want it smaller there, select the Image block and set a Width (e.g. 120px) on the mobile breakpoint.
    Let me know how it goes!
  • Thanks it worked!
    One more question in /barrio-de-la-boca-turismo-en-buenos-aires/ there is a grid with a slider but the vertical gap of 20 px doesn’t show
  • The Vertical Gap is the space between rows, so it only shows on mobile when the columns stack. I checked it and the 20px is there on mobile.
    The space between the text and the slider on desktop is controlled by the Horizontal Gap, which isn’t set on this grid. Select the Grid block, go to Layout, and set Horizontal Gap to 20px.
  • I thought it was the opposite.
    A big help, thanks.
  • Glad to hear that!
