willGreeny
Is there anyway to add query strings to query loops such as a utm_source etc. so I can tell the traffic came from that query loop?
Currently, it has dynamic links, but does not allow me to add any query string after it.
Kind regards,
Will
Hi Will,
Do you want to add the query string to the headline block in a query loop block?
If so, you might be able to use the
generateblocks_dynamic_url_output
filter to add it. -
willGreeny
I am using the dynamic data linking for a headline, let’s say a query loop for posts.
However, I want every link in the query loop of that dynamic link data to have a ?____ added to the end where ___ could be any query string – does that make sense?
Kind regards,
Will
What a coincidence. I was coming to the forum to see if that’s possible.
I use Matomo and I’d be really curious to know if the same link gets more clicks between the Headline, Image or Button inside a Query Loop. The sort of insight that can help figure out how to make a layout more effective.
Yes, you can use the
to add extra content to the link.Try this:
1. Add a class to the headline you want to target, eg.
add_query_string
.2. Add this PHP code, replace
'?____'
with actual code.add_filter('generateblocks_dynamic_url_output','add_query_string_to_dynamic_link', 20,2); function custom_query_loop_pagination($url , $attributes) { if( ! empty( $url ) && ! empty( $attributes['className'] ) && 'add_query_string' === $attributes['className'] ) { $query_string = '?____'; $url = $url.$query_string; } return $url; }
