QueryLoop WooCommerce Variation Product
  • Hey
    Would it be possible to show in query loop variations of woocommerce products? Like different colors?
  • Hello. Are your attributes global ones or product specific ones?
  • Product specific. Like in the screenshot showing two products with there different color options
  • Use this code to create a new custom dynamic tag for the Color variations you have created:
     * Register Product Colors Dynamic Tag
    function register_product_colors_dynamic_tag() {
        if (!class_exists('GenerateBlocks_Register_Dynamic_Tag')) {
            return;
        new GenerateBlocks_Register_Dynamic_Tag(
                'title'    => __('Product Colors', 'generateblocks'),
                'tag'      => 'product_colors',
                'type'     => 'post',
                'supports' => ['source'],
                'return'   => 'product_colors_callback',
    add_action('init', 'register_product_colors_dynamic_tag');
     * Product Colors Callback
     * @param array  $options  The options.
     * @param object $block    The block.
     * @param object $instance The block instance.
     * @return string
    function product_colors_callback($options, $block, $instance) {
        if (!function_exists('wc_get_product')) {
            return '';
        $product = wc_get_product(get_the_ID());
        if (!$product || !$product->is_type('variable')) {
            return '';
        $colors = $product->get_attribute('Color');
        if (!$colors) {
            return '';
        // Replace pipes or commas with slashes
        $colors = str_replace(' | ', ' / ', $colors);
        $colors = str_replace(', ', ' / ', $colors);
        return GenerateBlocks_Dynamic_Tag_Callbacks::output($colors, $options, $instance);
    In your query loop, insert a GB text block and open dynamic tags. The last entry from the Post is called Product Colors.
    Product colors dynamic tag
    Select that and check in the front end.
  • Thank you. Will that also show then the Color Variation Picture, if set?
  • No, it will also show Red / Blue for example, as you stated in your image.
  • Ok, but is there an way that images and price also gets shown then for the right variation? Also the correct link to that variation?
  • Sorry but that would require custom development which is out of scope of the current support forum. Hope you understand!
