ankitsheoran
Issue #1:
Select the Grid block and set the Grid Template Columns value to 1fr: https://cln.sh/TDY0VvlWRj0QJJ9Vb5H5Issue #2:
Add the following snippet:add_filter( 'generate_sticky_navigation_logo_output', function( $output ) { $site_url = 'https://example.com/'; $site_name = 'Example Site'; $title = '<div class="site-branding" style="margin-left: 20px;"> <p class="main-title" itemprop="headline"> <a href="' . esc_url( $site_url ) . '" rel="home">' . esc_html( $site_name ) . '</a> </p> </div>'; return $output . $title; } );Adding PHP: https://docs.generatepress.com/article/adding-php/
Make sure to replace the
$site_urland$site_namevalues with your own site details. After that purge the cache.Issue #3:
Depending on the type of image you’re using, you can use either an Image block or a Shape block:
https://learn.generatepress.com/blocks/block/image/
https://learn.generatepress.com/blocks/block/shape/
