Rankmath redirect page does not display
  • Hi. I’m using RankMath and for some time now I can’t see the content in the Redirects tab in the dashboard. These redirects are there (indicated by the number 32), but the page is empty – as if something is blocking its display. Here is the screen: https://i.postimg.cc/G2kjq7cg/temp-Image-Pfxul-R.avif and in a private message I give the access data.
    I have a second site, also on the GeneratePress theme, and there too the same problem.
    Hence my idea to write to you to ask if this is the fault of the theme, and if so – how to deal with it.
    the Theme doesn’t interfere with admin panels and has no control over what RankMath is doing.
    Check for plugin or child theme code conflicts by temporarily disabling them. If the issue persists reach ot to RankMath support
    Let us know what you find
