I can’t fix the read more button colors its showing weird 2 colors and changes on hover too.
Please see the attached link for seeing whats wrong
https://postimg.cc/jLybXPhn -
can you share a URL to the site where we can see the issue ?
Wp login url: https://cabotshores.com/wp-admin
Ok, so theres a lot going on there.
First off they are part of the beaaver builder content, and the button has two classes are:read-more button
which isn’t an issue other than there is a LOT of CSS rules that are getting applied to those classes.
I can’t see where exactly the CSS is loading from as it has been optimized but ti looks like a few plugins or custom CSS is at fault.A simple solution would be to throw more CSS at them eg.
a.read-more.button { background-image: none; width: auto; height: auto; }
The way more complicated solution is to track down where the other CSS is coming from and try to eliminate it.
Thank you, it worked. Not sure how to track all the css.
Yeah, i think the CSS above is the safe bet, as tracking the CSS is one thing, eliminating would be more problematic.
Glad to be of help
