I have a shortcode in a content template that calls get_the_excerpt. The issue is that the read more text is not translated, but it is translated in WP and GP. Where should I check more?
Best Regards,
Peter -
Why are you using a shortcode? Why not use the GP dynamic content block to show the excerpt?
Because sometimes the output should not be the excerpt but simply a download link.
function get_indhold_shortcode($atts) { global $post; // Ensure we're in the loop and have a valid post if (!isset($post)) { return ''; } // Parse attributes and set default value for altid_fuldt_indhold $atts = shortcode_atts(array( 'altid_fuldt_indhold' => false, ), $atts); $file = get_field('fil', $post->ID); $loop_content = get_the_content(); if ($file || filter_var($atts['altid_fuldt_indhold'], FILTER_VALIDATE_BOOLEAN)){ } else{ $loop_content = get_the_excerpt(); } // Remove HTML comments from the post content $sanitized_content = preg_replace('/<!--(.|\s)*?-->/', '', $loop_content); return wpautop($sanitized_content); } add_shortcode('indhold', 'get_indhold_shortcode');
i see, try changing your code to this:
function get_indhold_shortcode($atts) { global $post; if (!isset($post)) { return ''; } $atts = shortcode_atts(array( 'altid_fuldt_indhold' => false, ), $atts); $file = get_field('fil', $post->ID); $loop_content = get_the_content(); if ($file || filter_var($atts['altid_fuldt_indhold'], FILTER_VALIDATE_BOOLEAN)) { $loop_content = get_the_content(); } else { $loop_content = sprintf( '%1$s <a href="%2$s">%3$s</a>', get_the_excerpt(), get_permalink(), __('Read more', 'generatepress') ); } $sanitized_content = preg_replace('/<!--(.|\s)*?-->/', '', $loop_content); return wpautop($sanitized_content); } add_shortcode('indhold', 'get_indhold_shortcode');
That gives me two Read more. The new one is correctly translated but the one from the get_the_excerpt function is still there and not translated.
/ Peter
the
excerpt_more
filter hook allows you to alter the default read more text.
So with your original code, you could try this to filter in the Read More Text.function wpdocs_excerpt_more( $more ) { return __('Read more', 'generatepress'); } add_filter( 'excerpt_more', 'wpdocs_excerpt_more' );
Update: Turns out, the issue was actually staring me in the face the whole time! 😅 I completely overlooked the Read more label option in the settings for the blog in the customizer. Apologies for the unnecessary runaround, and thanks a million for the help anyway! 🙈 Cheers!
Glad to hear you found the issue
