Reading time with GenerateBlocks
    Is there any way to place the reading time of the blog post in the generablocks query loops, and inside the blog post as such?
    Are you using a plugin to add the reading time? Does the plugin offer a block or a shortcode?
  • Hello Ying,
    I am not using any plugin that has that functionality.
    I see. Could you share the link to where we can find your Query Loop?
  • Hello Fernando,
    The site is this: https://bkdev.site/
    I have been searching and found a snippet to add something similar with Rank Math.
    However it only works within the blog post, and not in the query loops.
    This is the script:
    add_shortcode( 'rm_reading_time', 'define_custom_shortcode_function' );
    function define_custom_shortcode_function() {
        global $post;
        $content = wp_strip_all_tags( $post->post_content );
        $words_per_minute = 250;
        $time = ceil(str_word_count($content)/$words_per_minute);
        return strval($time);
  • Add a GB Headline Block for the Reading time in your Query Loop.
    Then, type the shortcode [rm_reading_time] inside this Headline, add a CSS class to the headline, eg. get-reading-time. Adding Custom Classes: https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    Add this PHP code to render the headline:
    add_filter( 'render_block_generateblocks/headline', function( $block_content, $block ) {
        if (
          !is_admin() &&
          ! empty( $block['attrs']['className'] ) &&
          strpos( $block['attrs']['className'], 'get-reading-time' ) !== false
          $post_id = get_the_ID();
          $block_content = do_shortcode('[rm_reading_time]');
        return $block_content;
     }, 10, 2 );
