Search for: Recent Posts With Thumbnails ishare123 June 24, 2025 at 7:26 am Hi there, How to make Recent Posts appear With Thumbnails in the rightside bar? I use classic editor. Regards Ying June 24, 2025 at 9:29 am Hi there, You will need to write your own function in this case. If you can use block editor, then you can use GenerateBlocks’s query block to achieve that easily. Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
