Reduce LCP score
    I made some tweaks in WP Rocket to improve website speed. However, I am still failing core web vitals. I noticed it
    my LCP score needs improvement. When I checked the page insight, it’s with one display image of the recipe category, which is causing the issue.
    I have enabled lazy load for all images, but I did exclude this from the settings. I don’t know if I did it correctly. I have attached a reference below.
    Do you have any suggestions?
    Thank you
    This image is not lazy loaded, you did it correctly.
  • Hi Ying,
    Thank you for your reply. Is there anything I can do with this image to reduce LCP score?
  • Can you share the page in question so I can have a closer look?
  • Hi Ying,
    Here is the link.
    Thank you
    looking those images, it looks like theres a image optimizer running from a CDN, if thats the case then you need to check with the image optimizer and CDN provider.
  • Yes, David,
    I am using the image optimizer plugin. Okay, I will contact them.
  • You’re welcome
