Reducing spacing
    I’m trying to reduce the whitespace between the title and the paragraph below it – so the elements are closer together. I have tried removing margin and padding on the elements and containers they’re in. The elements are closer together in the WP editor, but then on the live site they’re still really spaced out. Please help!
    thanks
  • sorry – site is http://www.mallardhq.com
    Try reducing the heading bottom margin values under Customize > Typography.
    When you set a bottom margin directly on a Headline block in the editor, it should override the global value from the Customizer for that specific block.
