Remove blank space after native mega-menu.
  • Hello, I have a question regarding the change I made from the old menu that was in the top panel to the new native mega menu from GenerateBlocks.
    When I made the change following the documentation, a blank space appeared and does not connect anymore with the rest of the website.
    Can you help me figure out how to remove it? I have attached an image and URL.
    Thank you very much.
    Edit your site header element, and remove the empty paragraph block which is located below the site header block.
  • Wow, now it seems obvious, but I didn’t see that paragraph.
    Thank you very much, as always.
  • You are welcome   🙂
