johnottomagee
Hello Support !
See
https://johnottomagee.com/about/How do I remove the
“Built with WordPress” footer?Thanks.
John
George
Hi John.
Try using the code described at the Removing the entire footer bar section of this doc.
johnottomagee
That was fast.
Thanks, George.I created a PHP-snippet with:
add_action( ‘after_setup_theme’, ‘tu_remove_footer_area’ );
function tu_remove_footer_area() {
remove_action( ‘generate_footer’,’generate_construct_footer’ );
}The footer still appears.
I am out of practice how to do this stuff.
Please advise.John
George
Hi John.
Can you describe the process of adding this PHP snippet? Here are instructions on how to do it.
https://docs.generatepress.com/article/adding-php/
If you have used a snippet plugin, make sure the snippet is also activated.
johnottomagee
Hi George,
I have Woody Snippets as a plugin.
I went into and chose New Snippet: PHP.
Then inserted:add_action( ‘after_setup_theme’, ‘tu_remove_footer_area’ );
}and “Remove Everywhere”. Then updated.
George
Hello.
I imagine, you mean
Run everywhere?When using PHP snippets for this code, it is better to use a later hook that fires after Woody Snippets has loaded your code but before the footer renders:
add_action( 'wp', 'tu_remove_footer_area' ); function tu_remove_footer_area() { remove_action( 'generate_footer', 'generate_construct_footer' ); }Try this and let me know!
johnottomagee
Still there.
See screenshot:https://johnottomagee.com/wp-admin/post.php?post=123920&action=edit
George
Hello.
This link you sent is a link to the admin which I don’t have access to.
Could you please provide site credentials so we could have a look for you? Please use the private section of your reply to post them. You can also install the Temporary Login Without Password plugin and send us a login link without using a password. Again, please, use the private area of your reply to send those details.
johnottomagee
Sorry, my goof-up.
See in Private Info. -
George
Hi again.
Is it possible to give me admin access to have a look?
johnottomagee
See below, George, in
Private Info. -
johnottomagee
See Private Info, George.
George
Hey.
See here:
Please, set this to Run everywhere.
johnottomagee
Done. Solved.
Great work, George.And I apologize for being
so chaotic today.John
George
Not a problem, I am glad it’s solved!
