I’m using the theme MyPet. I’ve changed the footer colour in the footer block, but I can’t figure out how to remove the colour on either side of the block that is left over from the original theme.
Select the parent container from the one you just changed color from and change the background color in there. No need to modify the background color for the inner container you just changed.
