Anonymous
How can I remove the link from the title and image in the standard category loop?
The easiest way is to use this CSS:
body.archive.category .inside-article a { pointer-events:none; }
Anonymous
Hello Ying,
I don’t think the solution is particularly good because the source text still contains the link. This is very impractical for SEO.
Can’t you overwrite this with a hook?
When you say link, do you mean links of the title and image only? or do you mean the links in the post meta like author name/cateogry/tag/comments as well?
Anonymous
I mean only the link in the link in the entry-title an in the link post-image.
<div class="inside-article"> <header class="entry-header"> <h3 class="entry-title" itemprop="headline"><a href="xx/de/standorte/deutschland/museen-berlin/museum-fuer-naturkunde/" rel="bookmark">Museum für Naturkunde</a></h3> </header> <div class="post-image"> <a href="xx/de/standorte/deutschland/museen-berlin/museum-fuer-naturkunde/"> <img width="900" height="600" src="https://xxx/wp-content/uploads/museum-fuer-naturkunde-berlin-aussenansicht.jpg" class="attachment-full size-full wp-post-image" alt="Museum für Naturkunde - Berlin - Außenansicht" itemprop="image" decoding="async" srcset="https://xxx/wp-content/uploads/museum-fuer-naturkunde-berlin-aussenansicht.jpg 900w, https://xxx/wp-content/uploads/museum-fuer-naturkunde-berlin-aussenansicht-300x200.jpg 300w, xxx/wp-content/uploads/museum-fuer-naturkunde-berlin-aussenansicht-768x512.jpg 768w" sizes="(max-width: 900px) 100vw, 900px"> </a> </div> <div class="entry-summary" itemprop="text"> content.. </div>
1. to remove the link from featured image:
add_filter( 'generate_featured_image_output', function( $output ) { if ( ! is_category() ) { return $output; } return sprintf( '<div class="post-image"> %1$s </div>', get_the_post_thumbnail( get_the_ID(), apply_filters( 'generate_page_header_default_size', 'full' ) ), apply_filters( 'generate_inside_featured_image_output', '' ) ); } );
2. to remove the link from entry-title:
add_filter( 'generate_get_the_title_parameters', function( $params ) { // Check if we are in a non-singular context and not dealing with a "link" post format if ( ! is_singular() && 'link' !== get_post_format() ) { // Remove the link from the entry title $params['before'] = sprintf( '<h2 class="entry-title"%s>', 'microdata' === generate_get_schema_type() ? ' itemprop="headline"' : '' ); $params['after'] = '</h2>'; // Close the h2 without a link } return $params; } );
Anonymous
Hi Ying,
That seems to be the wrong hook. Neither works. That should be for the list in the category page.
Could you let me know how you added those snippets to your site? Both snippets should work for the standard archives.
