Remove Page Title
    I can’t figure out how to remove page title from the new home page I’m building: https://jenkuo.com/home/
    I have already applied the full width layout to the home page and disabled content title but it’s not getting rid of the page title (Home) on the page: https://www.loom.com/i/4bf1d587843343329cf7903b0490c8ee https://www.loom.com/i/9cc28f91c4454313b72ffd9649b8038b
    Thanks,
    Jen
    The login link doesn’t work for me – it says “You don’t have permission to access this page”
    That said, I believe that title is added by a Block Element Page Hero:
    https://docs.generatepress.com/article/block-element-page-hero/
    You can check under Dashboard > Appearance > Elements.
    Once you identify the element, simply add the page to the Exclusion section of the Display Rules.
    Let me know if this helps πŸ™‚
  • Hey Leo,
    The Defender plugin blocked the temporary access link, I’ve disabled 2FA for now so you should be able to login using the same login link I’ve provided.
    The page titles are automatically displayed by GeneratePress, I didn’t add “extra titles” to the page or any of my pages. I did use the Full Width Layout element for the home page and have made sure the “content title” is checked under “disable elements” but that didn’t do the trick πŸ™
  • fernandoazarcon2
    Hi Jenkuo,
    In Appearance > Elements, this element – “Front Page Title” – is adding the title. You’ll need to set your display rule so that the front page is excluded instead.
  • Ahhh, I didn’t realise this element is the culprit! Thanks Fernando πŸ™‚
  • fernandoazarcon2
    You’re welcome, Jenkuo! πŸ™‚
