Remove Post Titles and Create Archives in 3 columns
  • Hi
    Each property has info next to the images but the line spaces are too deep but the first 2 lines are fine.
    How can I also reduce the space padding at the top of each property?
    select each of the Headline blocks for the text.
    For example select the Ruamrudee – Lumphini block. In Spacing set the Margin Bottom to 0
    Repeat this for each of the headlines, or from the blocks Toolbar you can change the P tag to a DIV
    For the spacing at the top. Select the Top outer Container Block and in Spacing , remove/reduce its Top Margin.
  • Thanks David – this worked. The error was my bad!
  • Glad to be of help!
