How to remove only webPage and CreativeWork Schema From the website?
Are you using an SEO plugin?
yes but i disable these schema from seo plugin but still it is showing in webiste. when i change theme it disappear. check snapshot
If it’s now only GP’s schema left, try this PHP filter:
https://docs.generatepress.com/article/generate_schema_type/Adding PHP: https://docs.generatepress.com/article/adding-php/
but it will remove all GP schema. i want to remove only WebPage and CreativeWork schema
Can you try the snippet shared in this topic?
https://generatepress.com/forums/topic/remove-creativework-schema-2/#post-1670476
