Remove white space at top of pages
  • There is a white space above my header on all pages. How do I remove it? Site is TheCatholicTravelGuide.com
    It’s from the site title field, can you leave it empty if you don’t want it to show?
    It’s at customizer > site identity > site title.
    Let me know if this helps!
  • That didn’t work. May I mis-understood.
    When I remove the site title field the title of my website does not show….I just want to remove the white space above the header and title.
    Are you referring to this area?
    https://cln.sh/jQqKYbNg
    If so, it looks like there’s an issue with the output causing the empty space. It seems to be coming from Hook Elements. Try temporarily deactivating your Hook Elements to see if that fixes the issue.
