Removing “Last updated”
  • philipperoussel
    I missed entirely that the last updated text only appears if the post has been updated… ): Thank you!
    As for entirely deleting the update mention and its date for a specific post category (my question 2/), the code given by David does not seem to work. The category’s slug is guest-interview and I tried the following:
    .single-post article:not(.category-guest-interview) .posted-on .updated:before {
    content: “Last Updated “;
    Thanks again for your help.
  • Have you removed this CSS which is the 1st step David mentioned?
            content: "Last Updated "
  • philipperoussel
    Yes. All I have left is this:
    .posted-on .updated {
    display: inline-block;
    .posted-on .updated + .entry-date {
    display: none;
  • Then it should work.
    Can you link me to a post that is in category guest interview?
    The post you linked above is under the “Guest Interview” category. Based on the CSS you’ve added, the “Last Updated” text won’t be applied to this category.
  • philipperoussel
    Hi Alvind,
    The “Last Updated” text is not applied to this category (guest-interview) but the date does appear. How do I get rid of it as well for this category?
    Thank you.
  • Try adding this CSS as well:
    .single-post .category-guest-interview span.posted-on {
        display:none;
  • philipperoussel
    Beautiful! Thank you.
  • No Problem 🙂
Viewing 10 posts - 17 through 26 (of 26 total)
