bennyuk2
I’m trying to replace the default S M L in the block editor “typography size” box.
However I cannot get it to work for less than 6 custom sizes.I’m doing this via functions.php
// removes custom font sizes
add_theme_support(‘disable-custom-font-sizes’);
// add my own custom sizes
add_theme_support(‘editor-font-sizes’, array( …I’ve noticed that if define 6 or more custom font settings it works perfectly, eg
however with less that 6 WP bugs out and doesn’t display the options correctly.
Has anyone got a workaround for when setting less that 6 typo sozes?
Is there a better way to do this, eg theme.json? that works with GP?
Many thanks
Ben -
can you share the entire code snippet you’re trying ?
Please highlight the code and click the code button before submitting.
bennyuk2
following code placed in functions.php
If I have 6 or more entries, it appears as a dropdown, any less and it tries to squeeze into a row of select buttons
add_action( 'after_setup_theme', 'jb_custom_font_sizes' ); function jb_custom_font_sizes() { // removes custom font sizes add_theme_support('disable-custom-font-sizes'); // add my own custom sizes add_theme_support('editor-font-sizes', array( array( 'name' => esc_html__( 'BodySm', ' thewebsite' ), 'shortName' => esc_html_x( 'bodysm', 'Font size', ' thewebsite' ), 'size' => "1.6rem", 'slug' => 'bodysm' ), array( 'name' => esc_html__( 'BodyMd', ' thewebsite' ), 'shortName' => esc_html_x( 'bodymd', 'Font size', ' thewebsite' ), 'size' => "2rem", 'slug' => 'bodymd' ), array( 'name' => esc_html__( 'BodyLg', ' thewebsite' ), 'shortName' => esc_html_x( 'bodylg', 'Font size', ' thewebsite' ), 'size' => "2.4rem", 'slug' => 'bodylg' ), array( 'name' => esc_html__( 'ArrowList', ' thewebsite' ), 'shortName' => esc_html_x( 'ArrowList', 'Font size', ' thewebsite' ), 'size' => "2.1rem", 'slug' => 'ArrowList' ), array( 'name' => esc_html__( 'H6', ' thewebsite' ), 'shortName' => esc_html_x( 'H6', 'Font size', ' thewebsite' ), 'size' => "2.8rem", 'slug' => 'h6' ), array( 'name' => esc_html__( 'H3', ' thewebsite' ), 'shortName' => esc_html_x( 'H3', 'Font size', ' thewebsite' ), 'size' => "4.8rem", 'slug' => 'h3' ), array( 'name' => esc_html__( 'H2', ' thewebsite' ), 'shortName' => esc_html_x( 'H2', 'Font size', ' thewebsite' ), 'size' => "5.6rem", 'slug' => 'h2' ), array( 'name' => esc_html__( 'H1', ' thewebsite' ), 'shortName' => esc_html_x( 'H1', 'Font size', ' thewebsite' ), 'size' => "7.2rem", 'slug' => 'h1' ) ) ); }
Hmmm…. how odd, seems like some janky logic on WP, as it returns a completely different editor component with less than 6 items in the array.
Might be worth asking in WP support.
In the meantime ill ask if anyone in our dev team has a idea
