Responsive layout issues
  • Good day.
    I’m having some problems with editing responsive layout. I’ve used a Generateblocks “pricing table” template. It is 5 columns.
    It looks great but when you change the screen size, only 1 of the columns is displayed and the other four are simply not there….
    Here’s a link to page in question: https://techost.co.za/merriwabowls/membership/
    Can you tell me how to fix this?
    Many thanks
    Can you select the child containers of the Grid block, switch to tablet view, and remove all the values you entered for grid-column and grid-row? Do the same for mobile view as well.
    Let me know how it goes 🙂
  • Thank you Ying,
    That sort of works for the tablet view, but the text still protrudes out of the column.
    And for the mobile view, I still can’t see the other columns. They seem to be behind the first column.
  • but the text still protrudes out of the column.
    There are simply not enough space. Can you make the container wider by removing the 250px left and right margin set to container gb-element-371e4dd7?
    And I’m still seeing values in grid-column and grid-row, likely cache. Can you clear cache so I can see the mobile issue?
  • Thanks Ying,
    I’ll give that a try and let you know.
  • No Problem 🙂
