elliott
I am having an issue getting this sliding banner I created to sit well between two other elements. I am trying to get the spacing even on Website, Tablet & Mobile. Plugin is meta slider.http://www.onebrewing.ca (half way down home page)
Thank you!
The spacing looks even from my end: https://postimg.cc/p5NJ7Qt1
Is there any particular issue you want to address?
elliott
Hey Alvind,
Thanks for getting back to me. I am still having the issue show up on different sized screens. Here is a screenshot from my phone. -
the theme has no control over that, its Meta Slider that defines the Height of each Slide and it uses Javascript to calculate that. You would need to check with their plugin support to see how to alter that.
elliott
Hey David,
Thank you for your response. I actually ended up using the hide on feature to set up two different sliders (one for desktop and one for mobile).
Cheers,
Elliott -
Glad to hear you found a solution!
