Responsiveness Tablets
    I created a hero section with a background image on the right side.
    On iPad Air it looks like this.
    On iPad Pro it looks like this.
    How can I set the image dimensions so that the lady appears in the middle on all devices?
    Thanks in advance!
    Can I see the section on your site?
    You might need to adjust the background image position, or use an actual image block.
  • Hi Ying,
    I added the login info, so that you can check it.
    The page is still hidden and not published yet.
    Thanks in advance!
  • The image is pretty much centered, however, you’ve set gb-element-dad0ae3c’s display
    to block on tablet, which hides the image container, if you set it to flex, it looks like this:
    on iPad Air: https://app.screencast.com/nDJwVJP5rfzfn
    on iPad Pro: https://app.screencast.com/oPNE5trVaOBfj
  • Thanks Ying.
    That helps.
    By the way…
    How can I change the background color of the editor?
    In my case, It’s grey – see here – although the website design on the front end is white.
    Is it possible to change the bg colours of the editor?
    And:
    Today a new bug appeared when trying to modify the design in tablet view.
    I added the error code to the private info tab. Can you help to fix that?
    Thanks in advance!
    The editor background color inherits the background color set under Customize > Colors > Body > Background. You can change the color there to your preferred color.
  • Thanks Alvind!!
    And:
    Thanks in advance!
  • Can you try using a different browser to see if the error still appears?
    Also, there’s a possibility that a plugin conflict is causing the issue. Try deactivating all plugins except GP Premium and GenerateBlocks to check if any plugin might be responsible.
  • Thanks Alvind.
    Fixed it.
    Here’s another question:
    How can I avoid that the image in column 2 exceeds the width of the hero section?
    See here.
    Thanks in advance!
  • Have you already fixed it? This is what I’m seeing at the moment: https://cln.sh/pJYb6wfl
