HerrTim
I’d like to create a loop and show only posts that are 30 days old. Is there an easy way to realize this?
I think the standard only allows before and after date but not the “age” of a post.Thank you and best regards,
Tim -
The query loop block does not have this parameter.
You will need to write custom PHP code to add the argument, try below PHP code, and add
posts-in-30-days
class to the Grid block of the query loop block.add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if ( ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'posts-in-30-days' ) !== false && ! is_admin() ) { // Set the date query to only include posts published within the last 30 days $query_args['date_query'] = array( array( 'after' => '30 days ago', ), ); } return $query_args; }, 10, 2 );
