YEAR93
I’m using the Members plugin to restrict certain pages to logged-in users with specific roles. However, I noticed that some of my GeneratePress elements on these pages are still visible to everyone.
Is there a way to make these elements visible only to logged-in users with specific roles? If so, what would be the best approach?
That will require a custom snippet to achieve. For example, if you want to show the Elements with IDs 123, 124, and 125 to users with the ‘subscriber’ role, the snippet would look something like this:
function show_elements_to_subscribers( $display, $post_id ) { // Elements that should only be visible to subscribers $subscriber_elements = array( 123, 124, 125 ); // Check if this is one of our subscriber-only Elements if ( in_array( $post_id, $subscriber_elements ) ) { // Only show to logged-in subscribers if ( is_user_logged_in() ) { $user = wp_get_current_user(); // Check if user has the subscriber role if ( in_array( 'subscriber', (array) $user->roles ) ) { return true; } } // Not a subscriber, don't show the Element return false; } // Return original value for other Elements return $display; } add_filter( 'generate_element_display', 'show_elements_to_subscribers', 10, 2 );Adding PHP: https://docs.generatepress.com/article/adding-php/
If you have more specific conditions, let me know and I’ll help adjust the snippet accordingly.
