vuduproject
Hi Team!
I would like to be able to go back to the search box that expands in the menu (pre version 3.3), as opposed to the new one with the modal. Is it possible?Franz
I would advise against this as the previous navigation search has some accessibility issues which is why we introduced the search modal feature.
If you still prefer the previous navigation search then try this PHP function:
add_filter( 'option_generate_settings', function( $settings ) { $settings['nav_search'] = 'enable'; return $settings; } );Learn how to add PHP: https://docs.generatepress.com/article/adding-php/
vuduproject
thanks for the quick reply…now the old search bar appears. Can I activate something to draw it up as before?
the old search field never used to move, it always just appeared over the top of the header.
Do you have a different site that behaves differently ? -
vuduproject
hi David,
no I just want to see the search lens on the left, which if pressed searches for what’s in the input box… that’s fine, then I class it with jquery or vanilla on animate -
I see. If you would like to reposition the Search feature, for reference, can you share the link to the site in question? We’ll see what CSS is needed.
vuduproject
Hi Fernando
the search button on the left seems to be missing. Can I add it? I didn’t understand if it uses the classic searchform.php with hidden parts, or a custom one. dev.hermestrade.com -
The icon should be appearing by default. This is the
searchform.phpit uses: https://github.com/tomusborne/generatepress/blob/a4b04b12e1ad6c88c6109f23f196d61895f3d74b/searchform.php#L3I tried viewing the link you provided but it’s inaccessible. Can you check if it’s correct?
vuduproject
Hi!
The site is https://dev.hermescorporate.it/
Sorry for misunderstanding -
This is what I’m seeing: https://share.getcloudapp.com/7KuWEXkv
Do you want to alter the Search icon? Are you seeing something different?
vuduproject
Yes,I would like to replace the icons with material design.
I see. Add this snippet:
add_filter( 'generate_svg_icon_element', function( $output, $icon ) { if ( 'search' === $icon ) { $output = '<svg xmlns="http://www.w3.org/2000/svg" width="16" height="16" fill="currentColor" class="bi bi-hammer" viewBox="0 0 16 16"> <path d="M9.972 2.508a.5.5 0 0 0-.16-.556l-.178-.129a5.009 5.009 0 0 0-2.076-.783C6.215.862 4.504 1.229 2.84 3.133H1.786a.5.5 0 0 0-.354.147L.146 4.567a.5.5 0 0 0 0 .706l2.571 2.579a.5.5 0 0 0 .708 0l1.286-1.29a.5.5 0 0 0 .146-.353V5.57l8.387 8.873A.5.5 0 0 0 14 14.5l1.5-1.5a.5.5 0 0 0 .017-.689l-9.129-8.63c.747-.456 1.772-.839 3.112-.839a.5.5 0 0 0 .472-.334z"/> </svg>'; } return $output; }, 10, 2 );Adding PHP: https://docs.generatepress.com/article/adding-php/#code-snippets
You may replace the SVG code with your preferred SVG.
vuduproject
oh tnx!
For the hover color Can I quietly change the fill… to add the search to the side of the input just modify the searchform.php? -
Yes, you can alter the fill. For instance, you can try adding this through Appearance > Customize > Additional CSS:
span.gp-icon.icon-search svg { fill: #ff0000; transition: fill .4s ease-in; } span.gp-icon.icon-search:hover svg { fill: #00ff00; }You may replace the values to your liking.
With regard to “add the search to the side of the input”, are you referring to moving the icon to the right of the input box?
If so, try adding this through Appearance > Customize > Additional CSS instead of altering
searchform.php:form.buttonSearch.search-form.navigation-search.nav-search-active button { position: absolute; right: 0; z-index: 10000; font-size: 20px; } @media (max-width: 1024px){ form.buttonSearch.search-form.navigation-search.nav-search-active button { top: 33px; right: 20px } } -
vuduproject
Thank you!
To be able to change the other icons (close and burger menu)? Where can I find the php hooks legend? or is there another way? -
This article should help you regarding that: https://docs.generatepress.com/article/generate_svg_icon_element/
