vuduproject
tnx! look at the work so far
You’re welcome! Which specific icon did you change? I’m not seeing any changes. Perhaps I’m seeing a cached version of the site?
vuduproject
I Want to change menu-bar-item of off-canvas-open and close icon into searchbox nav… I would like to change these icons but I can’t find the hook in the ones you wrote to me
Try this:
add_filter( 'generate_svg_icon', function( $output, $icon ) { if ( 'pro-menu-bars' === $icon ) { $output = '<svg xmlns="http://www.w3.org/2000/svg" width="1em" height="1em" viewBox="0 0 1024 1024"><path d="M768 306.2V383H256v-76.8h512zM256 536.6h512v-76.8H256v76.8zm0 153.6h512v-76.8H256v76.8z" fill-rule="evenodd"/></svg>'; $classes = array( 'gp-icon', 'icon-' . $icon, ); return sprintf( '<span class="%1$s">%2$s</span>', implode( ' ', $classes ), $output ); } if ( 'pro-close' === $icon ) { $output = '<svg xmlns="http://www.w3.org/2000/svg" width="1em" height="1em" viewBox="0 0 1024 1024"><path d="M768 306.2V383H256v-76.8h512zM256 536.6h512v-76.8H256v76.8zm0 153.6h512v-76.8H256v76.8z" fill-rule="evenodd"/></svg>'; $classes = array( 'gp-icon', 'icon-' . $icon, ); return sprintf( '<span class="%1$s">%2$s</span>', implode( ' ', $classes ), $output ); } return $output; }, 15, 2 );Replace the SVGs with yours. Let us know how it goes.
vuduproject
tnx. The bars menu works but
Icon close doesn’t work. I need to change the one in search box that appears on click in the nav menu. PS. can i use the same method with the search icon? -
Let’s address the close icon first.
The close icon change code should work. Can you share the code you’re using? We’ll check why it isn’t working.
vuduproject
the code is the default one of the old navbar previous to the modal one, i just added this
add_filter( 'generate_navigation_search_output', function() { printf( '<form method="get" class="buttonSearch search-form navigation-search" action="%1$s"> <button class="material-symbols-outlined">search</button> <input type="search" placeholder="Search" class="search-field" value="%2$s" name="s" title="%3$s" /> </form>', esc_url( home_url( '/' ) ), esc_attr( get_search_query() ), esc_attr_x( 'Search', 'label', 'generatepress' ) ); } );on click search adds these classes menu-bar-item search-item active close-search on the span
I see. To clarify, are you referring to this close icon instead?: https://share.getcloudapp.com/nOuL5yXr
vuduproject
yes!! I would likes to change the close icon
This article provides the filter and the various values for changing the icon.
You can use theclosevalue in the filter eg.add_filter( 'generate_svg_icon_element', function( $output, $icon ) { if ( 'close' === $icon ) { $output = 'your svgs goes here'; } return $output; }, 10, 2 );You need to change
your svgs goes herefor your SVG -
vuduproject
Thank you very much it doesn’t solve my problem being two svg icons together but it made me understand a few things. Good job and thanks for now
OK, let us know if you need any further assistance
Glad we could be of help
