m_ali_88
The background seems to show on the wrong end on rtl site.
Please check video – https://drive.google.com/file/d/1VlOe69SNZ1AsoLahsudqGe3X1z1OYQOW/view?usp=drive_link
For the Arabic site the background needs to be behind the image.
Regards
hmmm…. tricky one as the background is a linear gradient and thats pure CSS so it will not respond to RTL.
You could try this:1. Select the Container Block that has the Gradient Attached to it:
1.1 set the gradients SELECTOR to Pseudo Element.
1.2 In Advanced > Additional CSS Classes add:has-gradient
Save that
2. In your CSS add this:
[dir='rtl'] .gb-container.has-gradient:after { transform: scaleX(-100%); }
What that should do is flip the pseudo element on a RTL site.
But you will have to do that for every container that has the gradient.
m_ali_88
Is there an easier way to do this, I am not so good with coding.
There isn’t unfortunately.
The only code required is part 2. Which you can copy and paste into the Customizer > Additional CSS at the very top. -
m_ali_88
Thank you. I followed the steps, it almost fixes the issue. The styling of image is still not right on RTL. There needs to be an empty space before the image.
OK, the only way to resolve that would be to change the design so that Container Block has equal Left and Right Padding….
