Mopade
As you can see in my website and in this picture : https://ibb.co/f9Xx1Py
Some times the text links are orange/red and not white.
Could you please help me to fix this issue ?
My website : https://www.les-neobanques.fr/
Thank you -
can you temporarily disable any CSS optimizations / caches on your site ?
Mopade
Yes, it’s done.
I use LiteSpeed Cache. -
OK, so Litespeed is messing with the order of the CSS.
If you check now, you will see your buttons are displayed correctly.Can you check with Litespeed support if they can change that behaviour?
The stylesheet that should be loaded last has an ID ofgenerateblocks-css
Mopade
OK thank you.
Is there a way to fix this with your help by adding custom CSS or something like this ?
If all the GB Buttons texts are the same color then you could try:
a.gb-button { color: var(--base-2) !important; }
Mopade
Perfect, thank you 🙂
You’re welcome
