SCF Plugin Fields Not Appearing in Dynamic Tags
  • I have created the custom fields using the Secure Custom Fields (SCF) Plugin. I am using GeneratePress Premium and Blocks Pro 2.4 version. I was expecting the fields to appear in the Dynamic Tags to allow the reusability of block with custom dynamic content.
    Following are my questions:
    Is the SCF compatible is GeneratePress/Blocks system?
    Is there any other settings to be done?
    1. It should be.
    2. Have you set the field’s REST API to true? Only if it’s set to true, GB can detect its existence.
    Let me know if this helps!
