landgorilla
I have a slider(slick slider) feature that I am working on. I works great when I test it outside of generatepress, but not when it is on a generatepress page. It seems like the scripts are not firing, or being allowed to modify the necessary divs.
The required scripts and css are being loaded via and element without any errors showing up—but nothing happens on the page.
hi there,
Have you tried using a custom HTML block to insert the same content from your test HTML page?
Let me know how that goes.
landgorilla
I found it works like this: I have to add the functions below the divs
<script>
$(‘.slide-show’).slick({
slidesToShow: 1,
slidesToScroll: 1,
arrows: false,
fade: true,
asNavFor: ‘.slider-nav’
$(‘.slider-nav’).slick({
slidesToShow: 1,
slidesToScroll: 1,
asNavFor: ‘.slide-show’,
dots: true,
centerMode: true,
focusOnSelect: true
</script>I will try to put it in an element and place it at the bottom of the page instead of having it in page.
