Scroll bar requested when pasting long CSS into Global Style
  • I built a CTA and wanted to have all the CSS in a single Global Style. Overall, it is about 80 lines of CSS that I pasted into the Edit CSS window, taken from the global styles page for GB.
    What I noticed was that there was no way to get back to the top by scrolling. I was able to save by moving the cursor back to the top in the CSS code.
    Small thing, but I thought I would share.
    PS – I just realized this was the alpha version and read the help doc. This is a nice new feature
    Thanks for reporting the issue.
    Is it possible to share your CSS so I can replicate the issue on my site?
  • The CSS has more lines than the CSS edit window. Now, when you move the cursor up or down and force a scroll, you see the bar, but it disappears and is not “grabbable”.
    background-color: var(–color-primary-800);
    padding: 2.5rem;
    border-radius: 8px;
    max-width: 640px;
    margin-left: auto;
    margin-right: auto;
    border-left-width: .33em;
    border-left-style: solid;
    border-left-color: var(–color-secondary-600);
    color: var(–color-neutral-50);
    font-family: Arial;
    display: flex;
    flex-direction: column;
    margin-top: 1.5rem;
    margin-bottom: 1.5rem;
    padding-top: 1rem;
    padding-right: 1rem;
    padding-bottom: 1rem;
    padding-left: 1rem;
    row-gap: 0px;
    column-gap: 0px;
    > div:first-child {
    display: flex;
    gap: 0.75rem;
    > div:first-child > p:nth-child(1) {
    text-transform: uppercase;
    font-size: 0.85rem;
    font-weight: 600;
    letter-spacing: 0.05em;
    color: var(–color-secondary-400, #c9a84c);
    margin: 0;
    > div:first-child > p:nth-child(2) {
    font-size: 1.5rem;
    font-weight: 700;
    line-height: 1.3;
    margin: 0;
    > div:first-child > p:nth-child(3) {
    font-size: 0.95rem;
    line-height: 1.6;
    opacity: 0.9;
    margin: 0;
    > div:first-child > div:last-child {
    display: flex;
    align-items: center;
    gap: 1.25rem;
    margin-top: 0.5rem;
    > div:first-child > div:last-child > a:first-child {
    background-color: var(–color-secondary-400, #c9a84c);
    color: #fff;
    padding: 0.75rem 1.5rem;
    border-radius: 6px;
    text-decoration: none;
    font-weight: 600;
    display: inline-flex;
    gap: 0.5rem;
    > div:first-child > div:last-child > a:last-child {
    color: #fff;
    text-decoration: underline;
    text-underline-offset: 3px;
    > div:last-child {
    margin-top: 1.25rem;
    padding-top: 1rem;
    border-top: 1px solid rgba(255, 255, 255, 0.25);
    font-size: 0.85rem;
    opacity: 0.85;
    line-height: 1.5;
    If you are referring to the current alpha versions, GenerateBlocks 2.3.0-beta.1 and GenerateBlocks Pro 2.6.0-beta.1 which are now live and downloadable from your account should have solved the issue.
    Let us know!
  • I just realized that GB was not on the alpha or beta. Now both are beta-1. I am adding a short video. If I use two-finger scrolling on a Mac, I can see and access the scrollbar. But it does not reappear when you hover over it. I would like it to be best to keep the scroll visible and not fade out. But I don’t know if that is a browser thing. See the loom video in the private area.
    MacOS scrollbars kind of get out of the way when they’re not needed.
    In System Settings > Appearance there should be an option: Show Scroll bars > Always.
  • Understood. After enabling scrollbars to always be visible, I now see it. Sorry, I did not realize the OS was impacting it. Thanks!
  • Ok, no problem!
