Search icon not changing
    I’ve added the following code to my functions.php:
    if ( 'search' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="16" height="16" fill="currentColor" class="bi bi-search" viewBox="0 0 16 16">
            <path d="M11.742 10.344a6.5 6.5 0 1 0-1.397 1.398h-.001q.044.06.098.115l3.85 3.85a1 1 0 0 0 1.415-1.414l-3.85-3.85a1 1 0 0 0-.115-.1zM12 6.5a5.5 5.5 0 1 1-11 0 5.5 5.5 0 0 1 11 0"/>
          </svg>';
    But the search icon of my WP Block Search input isn’t changing. How come?
    Try this instead:
    add_filter( 'generate_svg_icon_element', function( $output, $icon ) {
          </svg>';
        return $output;
    }, 10, 2 );
  • No didn’t work for me. I already had this in the correct function. This is the code of my function:
        if ( 'arrow' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="18" height="18" fill="currentColor" class="bi bi-chevron-down" viewBox="0 0 16 16">
            <path fill-rule="evenodd" d="M1.646 4.646a.5.5 0 0 1 .708 0L8 10.293l5.646-5.647a.5.5 0 0 1 .708.708l-6 6a.5.5 0 0 1-.708 0l-6-6a.5.5 0 0 1 0-.708"/>
          </svg>';
        if ( 'arrow-right' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="18" height="18" fill="currentColor" class="bi bi-chevron-right" viewBox="0 0 16 16">
            <path fill-rule="evenodd" d="M4.646 1.646a.5.5 0 0 1 .708 0l6 6a.5.5 0 0 1 0 .708l-6 6a.5.5 0 0 1-.708-.708L10.293 8 4.646 2.354a.5.5 0 0 1 0-.708"/>
          </svg>';
        if ( 'arrow-left' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="18" height="18" fill="currentColor" class="bi bi-chevron-left" viewBox="0 0 16 16">
            <path fill-rule="evenodd" d="M11.354 1.646a.5.5 0 0 1 0 .708L5.707 8l5.647 5.646a.5.5 0 0 1-.708.708l-6-6a.5.5 0 0 1 0-.708l6-6a.5.5 0 0 1 .708 0"/>
          </svg>';
        if ( 'arrow-up' === $icon ) {
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="18" height="18" fill="currentColor" class="bi bi-chevron-up" viewBox="0 0 16 16">
            <path fill-rule="evenodd" d="M7.646 4.646a.5.5 0 0 1 .708 0l6 6a.5.5 0 0 1-.708.708L8 5.707l-5.646 5.647a.5.5 0 0 1-.708-.708z"/>
          </svg>';
            $output = '<svg xmlns="http://www.w3.org/2000/svg" width="18" height="18" fill="currentColor" class="bi bi-search" viewBox="0 0 16 16">
          </svg>';
        return $output;
    }, 10, 2 );
  • Oh. Are you trying to alter the icon of the WordPress Search Block?
    If so, we have no control over that. That filter won’t work for that.
  • Okay thank you
  • You’re welcome!
    I just wanted to ask again if there is any possible way I can change the search icon of my search block to a Bootstrap icon, which I have been using throughout my whole website. View screenshot 1 shows the current search icon, and screenshot 2 displays the Bootstrap icon that I want to replace it with.
    </svg>
    We don’t have control over WP’s search block, please try reaching out to WP’s support for this.
  • Solved it with CSS. Thank you.
  • Glad you did 🙂
