Search Modal chebox box not appearing
  • When I disable the navigation search per the instruction, the checkbox to activate the new search modal does NOT appear. Please advise how to get that to work so I can customize the search function. I am using the most current version of GP.
    Go to cusotmzier > general, set icon type to SVG instead of font, and structure to flexbox instead of float.
  • Thank you! That worked and now the search bar is opens up and grey out the rest of the page when it opens. How would I customize it to open to the right of the icon or open a search bar below the main navigation menu?
    https://backwoodspursuit.com/gear-reviews/
  • How would I customize it to open to the right of the icon or open a search bar below the main navigation menu?
    It’s not possible, unfortunately!
  • Ok….what customizations are available then?
    The built-in search modal offers limited customization options. If you want to achieve the kind of customization you mentioned, you’d need to use a different solution such as a core Search block or a third-party search plugin.
